Erase Nvram via Rommon in Cat6506
May 17th, 2007
Hi team, i need to know how erase the configuration file via rommon in catalyst 6509. I change the configuration register to 0x2142 but the router back to load a configuration file.
mohammedmahmoud Thu, 05/17/2007 - 14:05
You should set the config-register of the MSFC not the supervisor, use one of the following links according to if you are running Native or Hybrid:
Hybrid:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_password_recovery09186a0080135657.shtml
Native:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_password_recovery09186a0080133fb1.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud Thu, 05/17/2007 - 14:17
The documents applies to the Supervisor 1, Supervisor 2, or Supervisor 720-based systems.
The difference between both, is whether you are running CatOS (Hybrid), or pure IOS (Native).
Mohammed Mahmoud.
