Reg: Preferences
Answered Question
May 17th, 2007
Hi Guys,
If I have two voip dial peers (with call managers address given in each one i.e. 10.1.1.1 and 10.1.1.2) configured, one with no preference command (call manager address 10.1.1.1) at all and one with preference 1 (call manager address 10.1.1.2). Which will be the primary call manager for the router. Is there any command to see which is the primary call manager on the H323 gateway.
Tks
Correct Answer by Chris Deren about 9 years 8 months ago
The default preference is 0, so the one without preference explicitely configured will be the prefered one, in your example dial-peer pointing to 10.1.1.2.
A good command to test this is "sh dialplan number xxxx"
HTH, please rate all useful posts!
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Thu, 05/17/2007 - 17:28
Chris
twissam Sat, 05/19/2007 - 10:06
I beleive it should be 10.1.1.1 as no preference is configured for that.
Good day
