Password Recovery on SSM Module ASA 7.2
May 18th, 2007
I want to do a Password Recovery on my SSM Module on ASA 7.2...Please guide with relevant info.
Overall Rating: 5 (1 ratings)
hoogen_82 Fri, 05/18/2007 - 09:43
hw-module module slot_number password-reset?This command recovers a password on a Cisco
ASA 5500 Series Content Security and Control Security Services Module (CSC-SSM) or the
AIP-SSM without having to re-image the device.
Note: This command starts support from IPS 6.0 (ASA 7.2 version) and is used to restore
the Cisco CLI account password to the default cisco
The command "hw-module module 1 password-reset" is only supported when the hardware
module is in the Up state and supports password reset.
More information on this command can be found here:
For AIP-SSM you may need to have 6.0 IPS. Also probably 7.2.(2) code would be good.
Do rate if this is helpful :)
