No syslog message when 4507R SUP V-10GE is removed
May 18th, 2007
I have a Cisco Catalyst 4507R with two Sup-Engine V-10GE.
When I remove from the chassis the active SUP-Engine, the switchover works fine, but there is no syslog message on the LMS syslog.
When I re-insert the module in the chassis, syslog messages appeared well on LMS syslog (module inserted).
The IOS is: 12.2(31)SGA1
the config is:
logging 172.30.7.240
snmp-server community fread RO
snmp-server community fwrite RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 172.30.7.240 f1matread
Joe Clarke Fri, 05/18/2007 - 07:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What messages do you have in your logging buffer on the switch?
