6509 switch
May 18th, 2007
Can someone tell me why I can't access my 6509 by telnet or console?
It's saying "Access not permitted. Closing connection." Even if I have the username and password for the switch.
Onin
Anand Narayana Fri, 05/18/2007 - 02:29
  • Silver, 250 points or more
Hi Ninora,
you get the message only while telneting the
switch or even for console also?
configured TACACS or RADIUS?
lemme know the status.
ninoramos Sun, 05/20/2007 - 18:46
I'm getting the message on both (telnet and console). It's configured on TACACS also.
Thanks for the reply and hope you can help me.
God Bless..
-= Onin =-
mahmoodmkl Sun, 05/20/2007 - 22:00
  • Gold, 750 points or more
HI
May be u have configured some access-list.can u check it.
Mahmood
Anand Narayana Sun, 05/20/2007 - 22:08
make sure on the TACACS server 6509 has been configured as a member, bcoz some times what happens is, if the TACACS commands are issued in the switches, but didn't make 6509 as a member in TACACS, u will face such kind of probz.
Ted Haubein Mon, 05/21/2007 - 08:01
It's possible that a timeout value is not specified for Telnet or the console.
ninoramos Mon, 05/21/2007 - 17:21
I used to access it before. How is that possible. But anyways, thanks for the reply.
So, password recovery won't work also?
