Switch IOS upload certification message
May 18th, 2007
I have uploaded a different IOS to a switch within a test environment for testing purposes, and happened to notice a specific message on the console. I upgraded from an IPbase code to an IPServices to enable routing functionality on a 3750. Has anyone seen the below message or can advise what it means?
"Failed to generate persistent self-signed certificate.
Secure server will use temporary self-signed certificate."
thanks
Phil
Overall Rating: 4.5 (2 ratings)
royalblues Fri, 05/18/2007 - 02:34
Phil,
Did you ever created a persistent self-signed certificate before upgrading the IOS?
BTW, a 3750 switch is a layer 3 switch and supports basic routing functionalities even with IPbase. You just need to enable it using IP routing command :-)
Narayan
phil_carter Fri, 05/18/2007 - 02:38
Narayan,
IPBase doesn't include OSPF... can you please explain what a persistent self-signed certificate is and what it is needed for?
thanks again...
royalblues Fri, 05/18/2007 - 02:46
Yes you would definitely require IP services for OSPF. I commented cos u mentioned just routing :-)
The Persistent Self-Signed Certificates feature saves a certificate generated by a secure HTTP (HTTPS) server for the Secure Sockets Layer (SSL) handshake in a router's startup configuration.
Have a look at this link
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008040adf0.html
HTH, rate if it does
Narayan
russell.turner Sat, 03/08/2008 - 21:04
I had received the same error messages. What I was able to determine and I don't if you have resolved this issue going by the date it was posted is see if you have configure ip domain name. When I configure a ip domain name the command ip http secure-server generated a certificate automatically with out the error. Hopes this help.
