carl_townshend Thu, 05/31/2007 - 04:16
when i set the qos value on my switch for the port, If the pc or device does not set its own value say for a paticular application etc, how do i make the switch apply the qos value to the traffic to the incoming frames ?
royalblues Thu, 05/31/2007 - 04:28
  • Green, 3000 points or more
Carl,
If your switch supports the features, then you can always classify the packets based on IP address, port no etc, at the ingress and mark them as required.
eg. on a 3750 switch
ip access-list extended VOICE
permit udp 100.100.100.0 0.0.0.127 any range 16384 32767
class-map match-all VOICE
match access-group name VOICE
policy-map VOICE-ACCESS
class VOICE
set ip dscp ef
interface fa 1/0/1
service-policy input VOICE-ACCESS
HTH, rate if it does
Narayan
carl_townshend Thu, 05/31/2007 - 04:35
thanks for your help, I know im a pain but could you explain what each line does? so all we are doing here is creating an access list that defines port number etc, and if there are any matches it applies the ef policy to them? also say if we have a phone that already marks the packets, what would we do here
again , many thanks
Carl
