Problem while CUE initialization
Answered Question
May 18th, 2007
I'm getting the following error while the CUE initialization using the CUE GUI initialization wizard...
"JTAPI login failed. Error while determining CCM version -1."
What could be problem?? can someone give your inputs on this..
I'm using NM-CUE with CUE version 2.3 and the CCM version 4.2(3)...
Correct Answer by dfokin about 9 years 10 months ago
While initializing, CUE tries to access a file at CCM server at the following URL: http:///CCMPluginsServer/CiscoJTAPIClient.exe
IIS in the CallManager is configured to "require SSL" in the CCMPluginsServer directory. Disable this requirement and install will continue.
Overall Rating: 5 (1 ratings)
Chris Deren Fri, 05/18/2007 - 06:29
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Is CTI Manager service started on CM? Did you configure CTI Ports, etc?
Chris
Correct Answer
dfokin Fri, 05/18/2007 - 06:32
rv_viji Sun, 05/20/2007 - 01:00
Yes, it solved my problem.
But should I have to enable the SSL requirement again??..
dfokin Sun, 05/20/2007 - 22:28
Yes, it should not influence on further work of both CCM&CUE.
