DCN: Cisco router cannot ping via clns a NE (ES)
May 18th, 2007
Dear all,
I am facing an issue with clns config under a cisco 2640 which i can not ping a specific siemens DQ.
The message i receive is:
cnls ... cannot send echo..
The funny this is that i can see the neighbor with the clns neighbors (NSAP)...
Is anybody familiar with DCN config/design with both IP/OSI networks?
Thanks in advance,
bwalchez Fri, 05/25/2007 - 05:45
let's try a 'trace clns' to the device that you cannot ping. This should give us some information on why it is failing.
