vlan interface administratively down
May 18th, 2007
I just created a vlan, assigned it to a port on our 6509, assigned the vlan an ip address and when i shoot the command, show int vlan 31 it says that the vlan is administratively down. I can't figure out whats going on here? i issued a no shut, to no avail.
royalblues Fri, 05/18/2007 - 04:45
  • Green, 3000 points or more
For the VLAN interface or the SVI to come up, you should have atleast one port connected to that VLAN or you should have a trunk configured in that switch
HTH, rate if it does
Narayan
guruprasadr Fri, 05/18/2007 - 05:38
  • Gold, 750 points or more
HI Brad.Thurston,
Try connecting some device/PC to the VLAN Port & can you please check the same.
Pls Rate if Helps ! !
Best Regards,
Guru Prasad R
brad.thurston Fri, 05/18/2007 - 06:13
Thanks guys for your help, I got stp going on the port. after a few seconds for propagation im sure, it came up
royalblues Fri, 05/18/2007 - 06:15
Brad,
You mean to say you had disabled STP on the switch?
glen.grant Fri, 05/18/2007 - 08:50
  • Purple, 4500 points or more
You need at least one active interface on that vlan , whether it is a user pc or just having the vlan included in a trunk in order for the layer 3 SVI come up , this due to the autostate function of the switch . Make sure the layer 2 vlan is created with the show vlan command.
