7206 Router : Difference btw Slot0: and Disk0:
May 18th, 2007
Hi All,
Can someone please confirm the difference between Slot0: and Disk0: on a 7206 router.
I've always understood Slot0: to be the usual PCMCIA flash card that you can plug and unplug from the router. However, I am not certain what Disk0: is then? Is it a physical hard disk inside the Cisco 7206 router?
Andrew
m.parry@skynets... Fri, 05/18/2007 - 04:54
Linear memory cards are addressed as the slot0: and slot1: devices. Flash Disk cards are inserted into the slot0 and slot1 physical slots but are addressed as the disk0: and disk1: devices.
Hope this helps
Martin
Andrew Morris Fri, 05/18/2007 - 05:10
Thanks Martin,
Does this also hold true then on the Cat 6509's?
Andrew
m.parry@skynets... Fri, 05/18/2007 - 05:15
Hi Andrew
I believe that with 6500's it is a little different.
On Sup1 and Sup2 the card slot is called slot0:
On Sup720 the card slot is called disk0: or disk1:
Martin
John Patrick Lopez Fri, 05/18/2007 - 06:23
Ei, just wanna follow up to the question. What is a linear memory card? So where does the PCMCIA fit? disk0 or slot0? Thanks.
