Check for available agents in another queue?
May 18th, 2007
Is it possible for a script to check for available agents in another queue, without removing them from the current queue, if someone has been waiting for 5 minutes or more?
I'm guessing you can but I'm not sure how to configure it. Anything to point me in the right direction would be appreciated.
Jake
walteryork Fri, 05/18/2007 - 10:49
Jake,
Attached is a screenshot of a script I designed that does most of what you are looking for. You will need to view the attachment while following the steps below.
-My if statement above the label, "Queueselect" checks to see if anyone is signed onto the skillsets listed, if someone is, it continues.
-Select resource automatically goes to a L1 queue first, then L2 and then a Supervisor. If all are unable to answer it increments the call loop. Notice that I am now queued in all 3 CSQ's.
-It then plays a prompt to the user (If Spanish1..) telling them that all agents are busy...
-Places the call on hold (for music on hold)
-Sets a delay for 30 seconds
-Removes from hold and loops back to Queueselect.
To satisfy your requirement, in the true portion of the, "if (CallLoop > 7) Then statement...
Add another select resource group for the queue you wish to add and make sure you modify your callLoop count to add up to 5 minutes.
Please let me know if this helps. Remember to rate helpful posts.
jake-savage Fri, 05/18/2007 - 10:56
That's pretty slick. I'll have to play around with this. Thanks for the update!
-Jake
