OSPF neigboring issue
May 18th, 2007
Hi, I have configured my router to run OSPF and established adj with other routers (thru switch). However there are 2 routers that wont established the adj. It keep appears below log. It is in the same network/subnet. The MTU is 1500. What is other posibble things to check?
FastEthernet5/0/0 from 2WAY to DOWN, Neighbor Down: Interface down or detached
royalblues Fri, 05/18/2007 - 05:22
  • Green, 3000 points or more
Mazlan,
Check the cable connection to fastethernet 5/0/0. There may be a speed/duplex issue which is causing the interface to go down and thus breaking your adjacency
HTH, rate if it does
Narayan
mazlan.alatif Fri, 05/18/2007 - 05:29
Narayan,
The connection is up. This interface also established ospf neigbor with other routers except 2 router. It keep stuck in exchange state. Also have check the MTU. It is same for all routers connected.
royalblues Fri, 05/18/2007 - 05:35
Mazlan,
If all the four routers are connected to a LAN segment, OSPF would choose a DR and BDR and all the routers would establish adjacencies only with these 2 routers.
But the status of the routers would not be in exchange but in a stae of 2-way..
Can you post your configurations
Narayan
guruprasadr Fri, 05/18/2007 - 05:32
  • Gold, 750 points or more
HI Mazlan, [Pls Rate if Helps]
After creating / "Changing" a OSPF router id inorder to take effect you need to reload the router / reset the ospf process. Pls try cmd below:
#clear ip ospf process
Reset All OSPF Process[n]:yes
#show ip ospf neighbor
Pls Rate if Helps ! !
Best Regards,
Guru Prasad R
mazlan.alatif Fri, 05/18/2007 - 05:37
Hi guruprasadr,
Why I need to change router ID. This router has established neigbor with other routers as well. However i have tried this but still same. :(
--mazlan
royalblues Fri, 05/18/2007 - 05:43
Would it be possible for you to paste the sh ip ospf neighbors from all the 4 routers
Narayan
guruprasadr Fri, 05/18/2007 - 05:44
HI Mazlan,
Try this command twice / thrice. Can you please check by rebooting the router.
Number of LSA's should be same on all the Routers.Check with "show ip ospf database database-summary" cmd to observe.
Check "show ip ospf database" to check the LSA's on all routers.
Best Regards,
Guru Prasad R
mazlan.alatif Fri, 05/18/2007 - 05:53
Hi Prasad,
Thank you. I have check the number of LSA and it is same througout the network.
Area 0 database summary
LSA Type Count Delete Maxage
Router 116 0 0
Network 30 0 0
Summary Net 2393 0 0
Summary ASBR 269 0 0
Type-7 Ext 0 0 0
Prefixes redistributed in Type-7 0
Opaque Link 0 0 0
Opaque Area 4 0 0
Subtotal 2812 0 0
guruprasadr Fri, 05/18/2007 - 05:58
HI Mazlan,
Whether this solved your Issue. Can you pls confirm / post the configuration.
Pls Rate if Helped you to identify / solve.
Best Regards,
Guru Prasad R
mazlan.alatif Mon, 05/21/2007 - 00:52
I have checked seems everything is ok. excpt it still wont established neigborship.. below logs keeps appears. have run debug i osf adj, the mtu is 1500.. any ideas??
May 21 16:47:50.754: %OSPF-5-ADJCHG: Process 1, Nbr 61.6.191.77 on GigabitEthernet0/0/0 from DOWN to DOWN, Neighbor Down: Dead timer expired
61.6.163.160 for invalid RP 161.142.158.14
May 21 16:49:11.431: %OSPF-5-ADJCHG: Process 1, Nbr 61.6.191.77 on GigabitEthernet0/0/0 from EXSTART to DOWN, Neighbor Down: Too many DBD retransmitions
Debup output:
May 21 16:51:32.417: OSPF: Retransmitting DBD to 61.6.191.77 on GigabitEthernet0/0/0
May 21 16:51:32.417: OSPF: 61.6.191.77 address 161.142.173.70 on GigabitEthernet0/0/0 is dead, state DOWN
May 21 16:51:32.417: %OSPF-5-ADJCHG: Process 1, Nbr 61.6.191.77 on GigabitEthernet0/0/0 from EXSTART to DOWN, Neighbor Down: Too many DBD retransmitions
May 21 16:51:33.388: OSPF: Nbr 61.6.191.77 161.142.173.70 GigabitEthernet0/0/0 is currently ignored
May 21 16:51:35.926: OSPF: Nbr 61.6.191.77 161.142.173.70 GigabitEthernet0/0/0 is currently ignored
May 21 16:51:38.641: OSPF: Nbr 61.6.191.77 161.142.173.70 GigabitEthernet0/0/0 is currently ignored
May 21 16:51:43.096: OSPF: Nbr 61.6.191.77 161.142.173.70 GigabitEthernet0/0/0 is currently ignored
Harold Ritter Mon, 05/21/2007 - 04:41
  • Cisco Employee,
Mazlan,
Can you try configuring "no capability lls" to see if it makes a difference.
Hope this helps,
mazlan.alatif Mon, 05/21/2007 - 05:13
Harold,
I have tried but still same. This router wont established neibor with one router.
It keep stuck at exstart state.
Harold Ritter Mon, 05/21/2007 - 05:15
  • Cisco Employee,
Mazlan,
Can you run a "deb ip ospf adj" on the opposite router as well.
mazlan.alatif Mon, 05/21/2007 - 05:28
Harold,
Below is the output from opposite router when i run debug ospf adj.
May 21 21:27:49.603: OSPF: Up DBD Retransmit cnt to 3 for 61.6.191.77 on FastEthernet5/0/0
May 21 21:27:49.603: OSPF: Send DBD to 61.6.191.77 on FastEthernet5/0/0 seq 0xDAB opt 0x52 flag 0x7 len 32
May 21 21:27:54.603: OSPF: Retransmitting DBD to 61.6.191.77 on FastEthernet5/0/0
May 21 21:27:54.603: OSPF: Up DBD Retransmit cnt to 4 for 61.6.191.77 on FastEthernet5/0/0
May 21 21:27:54.603: OSPF: Send DBD to 61.6.191.77 on FastEthernet5/0/0 seq 0xDAB opt 0x52 flag 0x7 len 32
May 21 21:27:59.603: OSPF: Retransmitting DBD to 61.6.191.77 on FastEthernet5/0/0
044102947 Mon, 05/21/2007 - 04:46
Hi Mazlan,
What kind of switch u are using to connect routers, if it is manageable please check the VLAN configuration of switch, or please check the HELO and HOLD DOWN timers on routers.
