QoS - effect of "set qos txq-ratio" command
May 18th, 2007
  • Gold, 750 points or more
The Cisco docs (CatOS on 6500) explicitly warn that if you use the "set qos txq-ratio" command then all ports flap - however, this doesn't seem to happen here.
Anyone have any experience of this?
thanks,
Andrew.
kfarrington Wed, 09/26/2007 - 03:37
Hi Andrew,
Yes I read this also, and tested it in the lab, and same as you. This does not happen.
If anyone else has clarification on this, would be great to know :)
Thx
Ken
