Modem dial in to C878 console port
May 18th, 2007
Hi All,
Wonder if you could give your opinion on the following please?
USR Sportster connected to console on a Cisco 878. The modem is configured for auto-answer and running at 115200 on the serial port. As the 878 doesn't actually have an AUX port - except what seems like a "virtual" AUX, I have set flow-control none on the console, tried setting the baud rate to 115200 etc.
Here's the config at the mo:
line con 0
password xxxxxx
login
modem enable
line aux 0
password xxxxx
login
modem InOut
modem autoconfigure type usr_sportster
transport input all
stopbits 1
speed 115200
When I dial the modem using hyperterm, it answers and connects. On the router I can see CTS and DSR are up, yet I get gobbledygook and wingdings on the terminal session and not the login prompt
do sh lin 1
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 1 AUX 115200/115200- inout - - - 1 144 0/0 -
Line 1, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 115200/115200, no parity, 1 stopbits, 8 databits
Status: Ready, Active, No Exit Banner, CTS Raised, Modem Configuring
Autoconfig Running
Capabilities: Modem Callout, Modem RI is CD, Modem Autoconfigure
Modem state: Ready
Modem hardware state: CTS* DSR* DTR RTS
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is usr_sportster.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are telnet ssh.
Allowed output transports are telnet ssh.
Preferred transport is telnet.
No output characters are padded
No special data dispatching characters
Any ideas please?
Ali
