cant send email to external addresses
May 18th, 2007
All, first, thanks for looking at this. I cant seem to send email to external addresses, and the only thing I have changed here is my firewall, which is now a pix. Can you guys see if you can see why I might not be able to send to external addresses please? By the way, we are doing this via pop3 to an internal exchange server, if that makes any difference. Thanks.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXXXXXXXXXXXXXXXX
passwd XXXXXXXXXXXXXX encrypted
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_outside permit tcp any host XXXXXXXXXXXX eq smtp
access-list acl_outside permit tcp any host XXXXXXXXXXXXX eq www
access-list acl_outside permit tcp any host XXXXXXXXXXXXX eq https
access-list acl_outside permit icmp any host XXXXXXXXXXXXX
access-list acl_outside permit tcp any host XXXXXXXXXXXXX eq pop3
access-list acl_outside permit tcp any host XXXXXXXXXXXXX eq pop2
access-list acl_outside permit icmp any any
access-list 102 permit ip XXXXXXXXXXXXX 255.255.255.0 XXXXXXXXXXXXX 255.255.255.0
pager lines 24
icmp permit any echo outside
icmp permit any echo inside
mtu outside 1500
mtu inside 1500
ip address outside XXXXXXXXXXXXX 255.255.255.248
ip address inside XXXXXXXXXXXXX 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool XXXXXXXXXXXXX
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 102
nat (inside) 1 XXXXXXXXXXXXX 255.255.255.0 0 0
static (inside,outside) XXXXXXXXXXXXX XXXXXXXXXXXXX netmask 255.255.255.255 0 0
access-group acl_outside in interface outside
route outside 0.0.0.0 0.0.0.0 XXXXXXXXXXXXX 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication enable console LOCAL
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
http server enable
http XXXXXXXXXXXXX 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set testTS esp-3des esp-md5-hmac
crypto dynamic-map dm 10 set transform-set testTS
crypto map staticmap 10 ipsec-isakmp dynamic dm
crypto map staticmap client authentication LOCAL
crypto map staticmap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup xxxx address-pool vpnpool
vpngroup xxxx dns-server XXXXXXXXXXXXX XXXXXXXXXXXXX
vpngroup xxxx split-tunnel 102
vpngroup xxxx idle-time 1800
vpngroup xxxx password XXXXXXXXXXXXX
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxx
: end
Overall Rating: 5 (1 ratings)
