Unity Connection v1.2.1 - "[drive letter]:\UC_Mailroot\UmssCsMalQueue
May 18th, 2007
Unity Connection is NOT delivering voice messages to Unity Inbox.
Messages are accumulating in "[drive letter]:\UC_Mailroot\UmssCsMalQueue", of the Unity Connection Server.
They are accumulating here and not moving to user voicemail inbox.
Unity Connection ver 1.2.1
Any ideas why this is happening?
darrenkemp Wed, 05/23/2007 - 05:18
Hi, Thanks for your reply...
I'm not running Mcafee, it has Cisco's security agent which comes as part of the unity connection install...
I did also see the above fix, but didn't see as relavent as I wasn't running Mcafee.
In the meantime, I have I copied / moved the voicemails from UmssCsMailqueue directory / folder into g:\inetpub\mailroot\dropdirectory... The messages then get delivered to the voicemail boxes and I get the MWI indicators... (that?s good)
SMTP service is running, but What service moves the voicemails from Mailqueue to drop folders??
Any ideas would be greatly appreciated?
Regards DK
Hernan Moya Wed, 03/04/2009 - 05:06
Hi DK,
I have the same problem and no info to troubleshoot this. Do you solve this problem?
Thanks.
