VPN Setup on Pix 515e
May 18th, 2007
Hello - I have a pix 515 that I am trying to enable VPN for. I went through the VPN wizard, choosing the options
Remote access
outside interface
PPTP
MSCHAP
Local VPDN - I set up a user
my Pool is 192.168.1.0-192.168.1.100 (inside network is 192.168.0.X)
I am pushing the dns server IP for the pix to the clients
I am leaving address translation exemption blank.
I can connect from outside the network, I just can't see the inside network.
What am I missing here?
I can post the running configuration if that would help.
acomiskey Fri, 05/18/2007 - 08:18
  • Green, 3000 points or more
isakmp nat-traversal
Just a guess with limited information, if not post your config.
njamabraasch Fri, 05/18/2007 - 08:25
Thanks for the response!
Is that a line in my config that I need to add? so far I've done some limited manual config changes, but I mostly work through the PDM. Can you elaborate?
acomiskey Fri, 05/18/2007 - 08:31
Yes it is. Not sure where it is in PDM, somewhere in the vpn options, but is probably a check box that says something about allowing inbound ipsec sessions to bypass interface access lists. Is this pix 6 or version 7? Oops, skimmed through too fast, you're doing pptp, don't think that will work. Post a clean config.
