3845 route
hoogen_82 Fri, 05/18/2007 - 09:04
  • Silver, 250 points or more
Post your show version from your router.
-Hoogen
royalblues Fri, 05/18/2007 - 09:07
  • Green, 3000 points or more
You would require either advance Ip services, enterprise services or SP services feature set in the IOS for BGP support.
BGP support was included even in the advance security feature set begining from 12.4
HSRP is supported in almost all releases.
You should try to use the latest IOS image as it has more bug fixes.
12.4.13b is the latest available on CCO for 3845 routers
HTH, rate if it does
Narayan
