Connecting to PIX 515 after lock-out
May 18th, 2007
Trying to perform password recovery on Pix 515. Put my laptop on 10.1.1.1 & PIX on 10.1.1.5, connecting via Eth0 but cannot ping thru. In monitor mode now (via hyperterm). Tried cross-over & straight...any ideas on what I am doing wrong??? thanks so much in advance
hoogen_82 Fri, 05/18/2007 - 10:59
  • Silver, 250 points or more
Did you set the interface outside command? Is your connection up?
This should be your procedure
monitor>interface 0
0: i8255X @ PCI(bus:0 dev:13 irq:10)
1: i8255X @ PCI(bus:0 dev:14 irq:7 )
Using 0: i82559 @ PCI(bus:0 dev:13 irq:10), MAC: 0050.54ff.82b9
monitor>address 10.21.1.99
address 10.21.1.99
monitor>server 172.18.125.3
server 172.18.125.3
monitor>file np52.bin
file np52.bin
monitor>gateway 10.21.1.1
gateway 10.21.1.1
monitor>ping 172.18.125.3
Sending 5, 100-byte 0xf8d3 ICMP Echoes to 172.18.125.3, timeout is 4 seconds:
Success rate is 100 percent (5/5)
monitor>tftp
tftp [email protected] via 10.21.1.1...................................
Received 73728 bytes
-Hoogen
Do rate if this helps :)
mauldin2006 Fri, 05/18/2007 - 11:58
Yes, thanks...I followed TID exactly and after turning off WIndows Defender on my laptop, I am able to ping one-way. Do I need a crossover cable attached from my PIX ether0 also? I didn't think I can TFTP viathe blue console cable & hyperterminal. ???
zulqurnain Sat, 05/19/2007 - 07:02
  • Bronze, 100 points or more
hello,
YES, if you are planning to TFTP your config then you would have to connect a crossover cable on your ethernet0 while connected via blue console cable & hyperterminal.
hoogen_82 Sat, 05/19/2007 - 09:11
You definately need a cross cable. Ping one way, are you sure you have your Windows firewall turned off in case you are running XP.
-Hoogen
