VoIP Configs
May 18th, 2007
Voice over IP (VoIP) supports the redirecting call feature of the VoIP gateway for ISDN calls. The redirecting number is an optional field of the Q.931 setup message. When a local exchange carrier (LEC) switch detects an incoming call that is destined for a busy or non answering party, the switch formulates a Q.931 setup message with the redirecting number field set to the original destination number and sends it to the gateway. The called party number of the setup message will be set to one of the destination number (Dialed Number Identification Service [DNIS])access numbers of the gateway. If a redirect number is present on an incoming call, it is used in place of the DNIS. To configure ISDN redirect number support, see the ?Dial Plans, Dial Peers, and Digit Manipulation? chapter.
The above documentation comes from Cisco?s manual.
I am trying to find someone who can provide a template or configs on how to configure CCM/Gateway to recognize the RDNIS from the PRI call setup. Nothing can be found on CCO.
paolo bevilacqua Sat, 05/19/2007 - 07:03
  • Hall of Fame,
    Founding Member
the above may or may not be true depending on the switch. In my experience, if someone has set call forwarding with telco, this is transparent to the caller and no information will be given.
If you receive a message containing RDNIS, please port the output of "debug isdn q931" here.
