pls help in a routing question
May 19th, 2007
RTA# show ip route ospf
O IA 6.0.0.0/8 [110/65] via 5.0.0.1, 00:00:28, Serial2/1/0
O* E2 0.0.0.0/0 [110/1] via 5.0.0.2, 00:00:16, Serial2/1/0
Refer to the exhibit. On the basis of the information presented, which statement is true?
A - A default route is configured on the local router.
B - Network 6.0.0.0/8 was learned from an OSPF neighbor within the area.
C - OSPF router 5.0.0.2 is an ABR.
D - The default route is learned from an OSPF neighbor.
Answer: B
I didn't got the idea of the answer, so anyone can help?
Overall Rating: 2.5 (2 ratings)
mohammedmahmoud Sat, 05/19/2007 - 06:52
  • Green, 3000 points or more
hi,
Answer B is correct as the "O IA" means Inter Area OSPF route --> route learned within the same area.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
ankbhasi Sat, 05/19/2007 - 06:59
  • Cisco Employee,
Hi Mahmoud,
AFAIK O IA are inter area routes which are originated from other areas and O are intra area routes which are generated from within area.
I believe answer B is correct because 6.0.0.0/8 is learned from neighbor which is within the area and I believe its learned via 5.x.x.x which may be its neighbor and may be in same area.
Ankur
*Pls rate all helpfull post
mohammedmahmoud Sat, 05/19/2007 - 07:13
Hi Ankur,
You are absolutely right "O IA" means Inter Area not Intra Area, i truly apologies for this newbie mistake :), and i think that your explaination is definitely right.
HTH,
Mohammed Mahmoud.
sharaf_sa Sat, 05/19/2007 - 20:33
Hi Ankur,
thanks a lot for your answer.any way, it seems that B is the correct answer even though it not clear that 5.x.x.x is within the area.
sharaf
JanicFerra Thu, 05/15/2014 - 10:41
Hi Guys.
I have a doubt, why "D" isnt correct?
Thanks in advance
