Chris Deren Sat, 05/19/2007 - 08:02
Make sure that you select the guest operating system as Red Hat Enterprise Linux 3, selct 2 GB of RAM, 72 Gig HD.
As the source use the DVD Drive or select the ISO if you are going to use iso instead.
That's it.
HTH,
Chris
Jon Nelson Sat, 05/19/2007 - 19:36
In addition to what Chris said, CM 5.x will install natively in VMWare as well. It will tell you that it is not a supported platform, but install just the same.
The other issue that you are going to run into is that you need to install a license for CM and DLU's for devices. Talk with your local Cisco office about getting their VMWare image or possibly helping you out with licensing as Cisco licensing *typically* doesn't allow you to register VMWare MAC addresses.
Jon
