troubleshooting IPSEC VPN LAN-toLAN
May 19th, 2007
PIX 515E's on both ends, one with version 7 of PIX IOS, and one with version 6 -- also, there are no firmware upgrades to the PIX running IOS v6.
IPSEC VPN drops completely in a completely random fashion, and it comes back up after the SA's are cleared. Is the best step at this point to upgrade the v6 PIX to all current firmware and PIX IOS versions? What would I look for after the upgrades if the issue were not resolved?
hoogen_82 Mon, 05/21/2007 - 04:22
Hi there i had this problem, but my scenario was like having a router connected to two PIX running 6.3 code. After several testing i got it to work in both 6.x and 7.x. I will attach the config for your reference. The configurations have been picked up from the cisco site only, and i believe it works pretty fine. Another thing could you have a debug isakmp sa and debug ipsec running on your pix so that we could find out the problem, post your logs in case you have collected the error messages.
-Hoogen
