setting up a dsl as failover on 2600 series router
May 19th, 2007
I need to setup a failover line. the primary line is a T1 which is connected to serial interface. the secondary line is install to the FE0/1 of a 2600 series router. when i configure the nat pool IPOOL i get a error message saying that dynamic maping in use i need to have a sample config to complete this
foxbatreco Sat, 05/19/2007 - 21:38
  • Bronze, 100 points or more
Hii,
the msg comes up in there at nat sessions moving on...so u need to clear the ip translations and try executing the command.. if still msg crops.then u might hv to shut the local inside nat interface for a while ..
pls do rate the post.
