Scripting Cisco Switches
May 19th, 2007
I'm trying to run a script to backup configs from Cisco switches with SSH and I can't seem to run a loop with the username/password saved for the session.
I'm using Teraterm macro at this time.
Anyone has any suggestions or examples? I'll post my config if anyone's interested.
Thanks.
Joe Clarke Sat, 05/19/2007 - 16:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't have any experience with TeraTerm macros, but I do have expect experience. How do you need to backup the configs (i.e. TFTP, simple screen scrape, etc.)? What switches running what IOS/CatOS?
parklabel Sat, 05/19/2007 - 16:46
For starters, I'm just trying to backup the configs (sh run, sh ver) from a couple of 6509 switches (IOS 12.2(18)). I'll have about 80-90 devices in a bit.
Another setback is that I don't have admin rights (yeah, I know) and I've only been able to use TeraTerm for scripting so far. I wish Putty had this feature.
Thank you.
Joe Clarke Sat, 05/19/2007 - 20:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Here is an expect script that will do what you want. It can be made to work on Windows provided you have expect for Windows (http://expect.nist.gov/) and OpenSSH for Windows (http://sshwindows.sourceforge.net/). It relies on a creds.txt file to exist in %HOME% (you may need to set this variable prior to running the script). For example, if you stick the script in C:\TEMP, create a C:\TEMP\creds.txt with:
username=parklabel
password=parklabel123
enable=enable123
Then:
set HOME=C:\TEMP
expect C:\TEMP\config_backup.exp 10.1.1.1
(Where 10.1.1.1 is the address of the switch).
This will create two files in C:\TEMP: 10.1.1.1.cfg and 10.1.1.1.ver.
