CUE Transfer to any extension help
May 19th, 2007
I need to set up a CUE script in where the caller can dial by extension at any time during the opening greeting. I've tried to configured but it drops the call as soon as I dial the first digit of the extension i want to reach. Can some shed some light. I've been using the Cisco scripts as a guide.
I have included the script.
CUE ver 2.3.4
Armando
gogasca Sat, 05/19/2007 - 22:41
You will need to input the digits one by one and make the decision.
Play the Menu prompt.
then call Get Digit String
After that compare String with Menu Definitions:
Option1="1"
Option2="2"
Option3="3"
for example:
Multiple IFs
If (String == Option1) go to OPT1
If (String == Option2) go to OPT2
If (String == Option3) go to OPT3
Else
Use call redirect step and transfer the call to the selected extension.
Or Use Switch Function to avoid multiple IFs
