Dialer pools - Checking which interface is being used
May 19th, 2007
Hi, how do you find out which interface is being used when you are using dialer group with multiple interfaces in the group?
Is there some sort of show command that tells you? I have tried "show int dialer 1" but it only tells me the virtual interface which the dialer is bound to and not the physical interface that is being used to make the connection.
Any information would be greatly appreciated. Thank you.
bjornarsb Sun, 05/20/2007 - 11:21
  • Bronze, 100 points or more
If I remember correct use this command:
sh ppp multilink.
Bjornasrb
voiper_99 Sun, 05/20/2007 - 16:45
Hi, sorry this does not show the information that I am after but thank you for the suggestion though.
spremkumar Sun, 05/20/2007 - 20:27
  • Red, 2250 points or more
can you try show isdn active and check ?
regds
voiper_99 Sun, 05/20/2007 - 20:34
This may work when ISDN interfaces are part of the pool but what happens if an ATM, ethernet or serial interface is being used? Thank you for your suggestion.
