Unity 4.0.x integration with CM4.2
May 19th, 2007
  • Bronze, 100 points or more
Per
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/401/integration/guide/ccm42u4x.html#wp1049135
To Enable DTMF Relay
Step 1 On a VoIP dial-peer servicing Cisco Unity, use the following command:
dtmf-relay h245-alphanumeric
Step 2 Create a destination pattern that matches the Cisco Unified CallManager voice mail port numbers. For example, if the system has voice mail ports 1001 through 1016, enter the dial-peer destination pattern 10xx.
I am running mgcp and fallback to srst on my gw and not sure on the relevance of this config. Any tech note or sample configs are appreciated.
