AUX port
join_sn09
Dear All,
Could you tell me, What is the AUX port and advantage for your this port?
I had some document but not clear.
Best Regards,
Join
2 Accepted Solutions
minumathur
i think , the port which you can remotely login though telephone line.
-minu
AUX port is usually used to get dial-in access to the router, and it can also support SLIP and PPP and dial-on-demand async network access, the Aux port can be in one of those types:
RJ-45
DB-25 DCE
DB-25 DTE
Check out these links:
Cabling Guide for Console and AUX Ports
http://www.cisco.com/warp/public/701/14.html
Configuring Dialout using a Modem on the AUX Port
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094579.shtml
Configuring a Modem on the AUX Port for EXEC Dialin Connectivity
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
Connecting Routers Back-to-Back Through the AUX Ports
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080093c7b.shtml
HTH, please do rate all helpful replies using the scrollbox on the right,
Mohammed Mahmoud.
minumathur
-minu
Dear Minu,
Thank you for your email.Do you have document for detail about aux port?
Best Regards,
join
RJ-45
DB-25 DCE
DB-25 DTE
Mohammed Mahmoud.
