05-20-2007 04:35 AM - edited 03-03-2019 05:03 PM
whats wrong with the below configuration. With only either the infrared or wireless is connected, theres no problem at all..once both are connected, then leds on port 25 and 26 on the moon switch will start to blink so fast and lost the connectivity from the core to the moon.
CORE SWITCH 1
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 2,10,12,14,16,216 priority 8192
spanning-tree vlan 11,13,15,100 priority 12288
interface GigabitEthernet1/44
description INFRARED TO the moon
no ip address
switchport
switchport access vlan 216
switchport mode access
interface Vlan216
ip address 172.20.254.202 255.255.255.248
standby 216 ip 172.20.254.201
standby 216 priority 115
standby 216 preempt
standby 216 track GigabitEthernet1/44 20
CORE SWITCH 2
spanning-tree vlan 2,10,12,14,16,216 priority 12288
spanning-tree vlan 11,13,15,100 priority 8192
interface Vlan216
ip address 172.20.254.203 255.255.255.248
standby 216 priority 105
standby 216 preempt
description Wireless connection to the moon
no ip address
switchport
MOON
spanning-tree vlan 24-25,27,200,215-216 priority 24576
interface GigabitEthernet0/25
description Infrared Link Connected to
core SW1
interface GigabitEthernet0/26
description Wireless Link Connected to
core SW2
05-20-2007 04:57 AM
As per u r configs the core 1 seems to be the root switch for u r 216 vlan and core the secondry.As STP will be in picture u r gig0/25 on moon will be blocked.
U didnt show how u r core switches are connected with each other.This might give us some insight.
Mahmood
05-20-2007 09:34 PM
isnt it port 26 should be blocked coz stp priority on vlan216 on core 1 is lower than the priority on core 2.
theres a layer 3 connectivity between the core as well as trunked layer 2.
05-22-2007 12:36 AM
which STP mode is the MOON switch running?
It looks like some RSTP+/STP compatibility problem.
See http://www.cisco.com/application/pdf/en/us/guest/tech/tk621/c1501/ccmigration_09186a0080174993.pdf
BR,
Milan
05-22-2007 11:20 PM
it is on rpvst
