Trunk groups and SRST (MGCP -> H323)
May 20th, 2007
  • Silver, 250 points or more
I can't seem to get trunk groups working when transitioning to SRST mode. If I reconfigure the trunk groups while in SRST mode, everything works great. But if I reboot the router and then go into SRST the trunk groups fail again. Debugs show that the channel is not available. I've opened a TAC case, and the engineer is suspicious to the fact that trunk groups on the T1 controllers will not work when they are MGCP first, then H323 (SRST trigger).
I've removed the ccm-manager config statement (since that was overwriting the configs on each reboot) so that's not the issue, the config statements are there upon reboot.
So in short, I've got the config working, but only when I enter the config commands while SRST is active.
Can anyone comment on the compatibility of trunk groups and SRST?
Here's a portion of the running config:
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
trunk-group uog_pstn_tg timeslots 1-21 preference 2
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:23
dial-peer voice 929 pots
trunkgroup uog_pstn_tg
destination-pattern 9[2-9].........
forward-digits 10
