CCM 5.1 and h323 gateway
Hello all!
I need your help! I try to connect CCM and my h323 provider.
[ISP]---[2811]---[CCM]
Call came from provider to my 2811 and should be translate to CCM, but - I can get call, but after 5 sec. connectons droped, no voice on both end. Why? How can I debug what is going on?
My second problem - no call route outside my network. I add h323 gateway, create route group/route list/route pattern, CCM trying to place call, but after 30-40 sec. i can't place a call. How can i see logs/debugs about WTF ig going on CCM? I can debug and trace everything on 2811, but how can i debug a call on CCM?
My 2811 config is:
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
interface FastEthernet0/1
description ==C2811_CONNECT==
ip address 192.168.5.2 255.255.255.252
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id c2811
h323-gateway voip bind srcaddr 192.168.5.2
dial-peer voice 5 voip
destination-pattern 1010
voice-class codec 1
session target ipv4:192.168.5.1
dtmf-relay h245-alphanumeric
no vad
Chris Deren Sun, 05/20/2007 - 15:36
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
How si the GW connected to PSTN, what circuit do you have? PRI, CAS, FXO, SIP????
Chris
