No QoS Stats on Cat 3750 VLAN
Answered Question
May 20th, 2007
Dear Support,
Have a small setup of 4 site, and using QoS to mark certain traffic.
However, I'm not sure if it's working or that the ASIC's on the switch don't allow for tracking the stats like a router.
I've done the marking and classification on the VLAN rather than the port, and set the routed port that connects between sites to 'trust' the markings.
Can someone point me in the right direction?
Thanks in advance.
I always rate helpful posts.
class-map match-any SAN-Replication
description Mark SAN replication traffic based on ACL Match-SAN
match access-group name Match-SAN
class-map match-any VOICE-Control
match ip dscp af31
match ip dscp ef
class-map match-any Citrix-Traffic
description Match Citrix Traffic based on ACL Match-Citrix
match access-group name Match-Citrix
policy-map BRANCH-WAN-EDGE
class Citrix-Traffic
set dscp cs3
class SAN-Replication
set dscp af41
class VOICE
set dscp ef
class VOICE-Control
set dscp af31
class class-default
set dscp default
ip access-list extended Match-Citrix
permit tcp any eq 1494 any
permit tcp any any eq 1494
remark Match Citrix ICA traffic based upon TCP 1494
ip access-list extended Match-SAN
permit ip host 192.168.104.100 host 192.168.204.100
permit ip host 192.168.204.100 host 192.168.104.100
remark Match SAN replication Traffic
ip access-list extended SAN-Replication-Traffic
remark ACL to identify SAN replication traffic
route-map PBR-for-SAN permit 10
match ip address SAN-Replication-Traffic
set ip next-hop 192.168.254.2
route-map PBR-for-SAN permit 20
interface FastEthernet1/0/1
description LES 100 circuit to site1
no switchport
ip address 192.168.254.5 255.255.255.252
ip ospf network point-to-point
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust dscp
auto qos voip trust
interface FastEthernet1/0/3
description LES 100 circuit for SAN
no switchport
ip address 192.168.254.1 255.255.255.252
ip ospf cost 3
speed 100
duplex full
mls qos trust dscp
auto qos voip trust
interface FastEthernet1/0/5
description LES 100 circuit to site2
no switchport
ip address 192.168.254.9 255.255.255.252
speed 100
duplex full
mls qos trust dscp
auto qos voip trust
interface FastEthernet1/0/7
description server port
switchport access vlan 100
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
interface FastEthernet1/0/8
description user port
switchport access vlan 304
interface Vlan100
description Server VLAN DR Site
ip address 192.168.100.250 255.255.254.0
service-policy input BRANCH-WAN-EDGE
shutdown
interface Vlan304
description Management VLAN
ip address 192.168.204.250 255.255.255.0
ip policy route-map PBR-for-SAN
router ospf 100
log-adjacency-changes
network 192.168.100.0 0.0.1.255 area 0
network 192.168.204.0 0.0.0.255 area 0
network 192.168.254.0 0.0.0.3 area 0
network 192.168.254.4 0.0.0.3 area 0
network 192.168.254.8 0.0.0.3 area 0
Correct Answer by johgill about 9 years 8 months ago
QoS on a switch is mostly about Tx queues and the mappings of markings. The marking and policing happens in policy-maps, but not much else usually - very different from router QoS.
Be careful on switches, "show policy-map interface" is not supported for stats on the 3750. Always be sure "mls qos" is enabled, and think of QoS as a L1 technology, to be used on physical interfaces.
You can use VLAN-based QoS, but remember that policy gets applied as a copy to the interfaces who have "mls qos vlan-based" configured, and in that VLAN.
Some good stats for the 3750/3560/2960 are:
sh mls qos int stats
sh plat port-asic stats drop
sh plat port-asic stats enq
Until QoS is enabled, the stats count on the last queue, last threshold. You cannot clear the port-asic stats, but you can clear mls qos int stats with "clear mls qos int statistics".
Also, "class default" is not supported either.
Overall Rating: 3.3 (3 ratings)
bjornarsb Mon, 05/21/2007 - 00:40
First I would say that you should do marking and classification on input and then QOS on your output wan interface.
Second I cannot see that you are doing QOS , you have just configured marking.
Does your ISP's configuration match your marking ?
exa:
!--- Create a class map named Voice.
Router(config)#class-map Voice
!--- Specifies the packet that matches criteria that
!--- identifies voice packets that have a DSCP value of "ef".
Router(config-cmap)#match dscp ef
!--- Create a policy to be applied to a set
!--- of voice traffic.
Router(config-cmap)#policy-map Voicepolicy
!--- Specify the class name created in order to apply
!--- the action to it.
Router(config-pmap)#class Voice
!--- Strict scheduling priority for the class Voice.
Router(config-pmap-c)#priority
!--- Apply the policy defined to the outside interface.
Router(config-pmap-c)#service-policy Voicepolicy interface outside
To have full utilization of QOS you need to aggree with your ISP on both output traffic and return traffic.
Bjornarsb
aoshea Tue, 05/29/2007 - 03:50
Hi Bjornarsb,
Many thanks for the reply, I believe I've worked out myself what the issue was, on catalyst switches VLAN classification the port needs to be configured;
i.e.
mls qos vlan-based.
thanks anyway.
regards, adrian.
Correct Answer
johgill Tue, 05/29/2007 - 13:36
