Calhoun LED Proc
May 20th, 2007
We have four identically configured Cisco Switches (2950 running 12.1(22)EA2)
One of them has a high CPU (20%) while the rest are 1%. None of them are really doing much, no traffic currently going through them. The one with a high CPU has this process to blame...
20 400615112 49492703 8094 16.95% 16.97% 16.01% 0 Calhoun LED Proc
While the others are much lower...
20 569772 59394695 9 0.00% 0.00% 0.03% 0 Calhoun LED Proc
Amit Singh Mon, 05/21/2007 - 20:35
  • Cisco Employee,
The CPU on the 2950 switch normally runs around 20-40% with no load. The LED processors are usually between 8 and 20% even in a no load situation.
Calhoun LED Process: decoded means that this switch has the Calhoun board, (this is a nick name that the programmers gave it) and that the processor is running at x%. LED is referring to the actual LED's on and in the switch.It has been seen that this does not affect the switch performance.
The Calhoun does a lot of things:
- Updates statistics and error counters in port LED config, to update the blink profile.
- For each port, calculates the next color to be displayed based on the blink profile and the mode.
As I mentioned, this value is seen very often and if the switch is not having any latency issues, it should not cause a problem.
HTH,Please rate if it does.
-amit singh
