Modem Connected to VG224
May 20th, 2007
Hello Guys
I have a VG224 coonected to my CCM using SCCP.
I have a telephone connected to voice-port 2/0 in the VG224 and it works fine, but if i connect a modem in the same port, the modem dont ring, in fact i dont even get signal to the modem from the VG.
Any clues about this? should i have a special configuration on the VG?
THX in advanced.
Current COnfig:
CCM 4.2
VG224: Version 12.4(10b)
ivillagomez Tue, 05/22/2007 - 09:57
I found the problem, after some testing the modem was ringing answered the call but didnt established the communication. all i did was to use MGCP and it works now.
For incoming call from the outside to that modem i had to configure the modem-passtrough command on the dial-peer voice voip.
