Custom queing question
Manoj Wadhwa
Friends,
I am configuring custom queueing on my test router. I realized that even after changing the queue length, the new queue length does not reflect in the interface statistics. Ex. as per the below output, i changed the byte-count of queue 1 to 1000, however in the interface output, it still shows as 20 "1: 0/20/0". Plz assist with this. Thanks!
R1#sh queueing custom
Current custom queue configuration:
List Queue Args
1 2 default
1 2 protocol ip list 110
1 1 byte-count 1000
1 2 byte-count 9000
R1#
R1#sh int se1/0
Serial1/0 is up, line protocol is up
Hardware is M8T-X.21
Internet address is 10.10.20.1/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:01, output 00:00:02, output hang never
Queueing strategy: custom-list 1
Output queues: (queue #: size/max/drops)
0: 0/20/0 1: 0/20/0 2: 0/20/0 3: 0/20/0 4: 0/20/0
5: 0/20/0 6: 0/20/0 7: 0/20/0 8: 0/20/0 9: 0/20/0
10: 0/20/0 11: 0/20/0 12: 0/20/0 13: 0/20/0 14: 0/20/0
15: 0/20/0 16: 0/20/0
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
106 packets input, 7326 bytes, 0 no buffer
Received 39 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
68 packets output, 4856 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
5 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Manoj
The queue-list queue byte-count counts the number of bytes in packets that are in queue. For this purpose it does not matter how many packets, just how many bytes are in the packets. This is because the queuing is trying to determine how much data to send from this queue at a time and the important variable is how many bytes to transmit (not how many packets).
The queue-list queue limit is used to configure the limit of how many packets can be maintained within the specific queue.
Rick
Rick
5 Replies 5
bjornarsb
Level 4
Level 4
Since you have:
List Queue Args
1 2 default
it refer to list 1 and you have Queueing strategy: custom-list 1 and then you get default. It hits default first. remove 1 2 default .
Try this:#queue-list 1 queue 2 limit 1000,
since its size/max/drops
Bjornarsb
Hi Bjornarsb,
Thanks for your reply. Can you also help me understand what the difference between byte count (queue-list queue byte-count ) and queue-list queue limit commands. Thanks!
Manoj
Rick
Rick
Rick,
Thanks for the explanation. I was confused between bytes & packets and your explanation has cleared my confusion. Cheers!
Manoj
Manoj
Yes I agree that it can be a bit confusing in understanding where it is using bytes to establish its controls and where it is using packet counts. I am glad that my answer was helpful.
Thanks for using the rating system to indicate that your question is solved. (and thanks for the rating) It makes the forum more useful when people can read a question and can know that an answer was provided which satisfactorily answered the question. I encourage you to continue your participation in the forum.
Rick
Rick
