Can't create VLAnNfrom config mode
May 20th, 2007
CAT 6500 running 12.2(17d)SXB11a or 12.2(17d)SXB4.
I go into config mode and say
(config#)interface vlan 140
no shut
int gi4/9
switchport access vlan 140
no shut
Then I do
router#show vlan
and I do not see vlan 140
router#show interface vlan 140
shows line down / protocol down
Then I go into
vlan database
show current
and vlan 140 is not there.
Then I type vlan 140 under vlan database to create vlan 140 and then everything is fine.
show vlan - shows vlan 140 active
and show interface vlan 140 says line up / protocol up.
But I shouldn't have to go to vlan database and type vlan 140 - right? Creating VLANs under vlan database is something that we don't have to do nowadays - right?
spremkumar Sun, 05/20/2007 - 20:34
AFAIK the general process seems to be create vlan under vlan database and then create a SVI interface (SVI - VLAN interface with ip address) assign the same to an interface which is connected and up.
The above process is still the same and i dont thin theres a change and if in case of normal L2 vlans (to which you dont really want to assign an ip address and make it as SVI) you don't need to follow that extra step..
astanislaus Sun, 05/20/2007 - 21:02
I just found that I do not have to go to vlan database, but go to ocnfig and do
(config#)vlan 140
(config#)ip address x.x.x.x x.x.x.x
