upgrade to a NP-225 to NPE-G2
May 20th, 2007
I am planning for upgrade to a NP-225 to NPE-G2 on 7204 VXR router.I have also got 1 GB memory module.Can you pls guide me how to go about it in simple way.
I am also not planning to remove the I/O controller card.
Overall Rating: 3 (1 ratings)
saugatobanerjee Sun, 05/20/2007 - 23:33
Hi ,
Thanks for your reply. But can you inform me regarding any stable IOS(as per Cisco it is 12.4(4)XD ) that you may be successfully using which support SSH2 access.
