managing switch
May 20th, 2007
as we know vlan1 is default & native vlan,VLAN1 is used only for Management. & for VLAN1 we assign as IP Address for Management of Switch in remote.
1. I would like to know what are operations we manage on switches. following r the operation that i know correct me if I'm wrong: operations like taking backup, verify configuration detail. and i also request you to add some operation we perform and when & why we perform.
2. what information does vlan1 carrys
what i know is it carry vtp advertisement.
Overall Rating: 3.3 (3 ratings)
ankbhasi Sun, 05/20/2007 - 22:19
  • Cisco Employee,
Hi Friend,
We manage switches for making any configuration changes, for any troubleshooting purpose, to get the stats of an interface etc etc.
Vlan 1 carries VTP, CDP , Stp bpdus etc.
Ankur
*Pls rate all helpfull post
Jon Marshall Sun, 05/20/2007 - 23:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
In addition to Ankur's post Cisco best practice says not to use vlan 1 as management or for the native vlan. As a rule you should
1) Use a different vlan for management and shutdown vlan 1 interface.
2) Allocate all unused ports to a non-routed vlan - we use vlan 998 where i work.
3) Allocate a non-routed vlan for use as the native vlan - we use vlan 999.
Vlan 1 has some specific issues with it in terms of security and hence it is recommended not to use it. VTP, CDP & PAGP will still be carried on vlan 1 even if you don't use it.
Jon
smothuku Mon, 05/21/2007 - 00:35
  • Silver, 250 points or more
Hi ,
In addition to above posts , it is a layer 2 device then you need to specify "ip deafilt-gateway " for reachability from outisde users which are in different vlan's.
Satish
