Reg: incoming called-number command
May 20th, 2007
Hi Guys,
I know that incoming called-number command is to tell the router what kind of call is that. Whether it is for modem or for voice.
What does the following means:
incoming called-number 0...
The external number assigned by the ISP is in the range of +85 6172 4100-4200. So not sure what the above command means. The configuration of the dial-peer where this command is specified is given below:
Dial-peer voice 200 pots
destination-pattern 0T
translate-outgoing calling 3
incoming called-number 0....
port 0/3/0:15
Any suggestions?
