Unity Unified Messaging to Unity VoiceMail
May 21st, 2007
Hi all,
Our customer doesn't want anymore to receive his Voice Message in Outlook Inbox, so he'd like to reinstall unity as Voicemail only. Is there a way to do it without reinstalling the server from scratch ?
Thanks for ur help
Fabian
ranpierce Mon, 05/21/2007 - 06:48
  • Silver, 250 points or more
All the tools that I have found go from VM to UM. It is looking like this might be a reinstall unless a DE tells us otherwise. Jeff, Chris, Eric, anyone?
The closest tool I found is Migrate Subscriber Data if it can be used UM to VM.
But it didn't look like it.
rlp
f.giordano Mon, 05/21/2007 - 06:53
Thx for your help.
If it's the only way to do this, I will reinstall the server from the beginning... :(
See u
Fabian
ranpierce Mon, 05/21/2007 - 07:01
Fabian, I was just thinking about it and you can probably use DiRT and do a Back up of your UM and restore it to a VM domain.
Look at the DiRT videos and help file.
rlp
