How to change 7912 ip addres and default gateway
Answered Question
May 21st, 2007
I have configured DHCP server to give ip adresses to all my registered phones but I would like to give an specific ip adress and default gateway to a phone.
I use CCM 4.1 and firmware of my phones is 8.0.2.
Thanks.
Correct Answer by George Venianakis about 10 years 2 months ago
First disable the DHCP from the phone, then manually assign IP, Mask and Gateway. Check out the following instructions:
http://www.cisco.com/en/US/partner/products/hw/phones/ps379/products_administration_guide_chapter09186a008047389b.html#wp1031045
I hope this helps.
Cheers.
Overall Rating: 5 (1 ratings)
