reimaging a 1112 appliance to 4.1
May 21st, 2007
I have been trying to upgrade a secure ACS appliance to 4.1 and having issues. If I use the recovery CD TAC had me build it boots and lets me select " re-image hard drive" etc but I loose console access. If I watch the monitor the upgrade (ghost) seems to go as planned but again I loose console access..I can use the 3.3.3 recovery CD and everything works great. Should going to 4.1 be this hard?
Jagdeep Gambhir Mon, 05/21/2007 - 05:56
Hi ,
Is there any specific time you loose console access ? Nothing special needs to be done for reimageing 4.1.
Make sure the recovery image is for model 1112 and not for 1111 or 1113.
