ASA V7.2 Initial Sequence Number (ISN) Randomization
May 21st, 2007
Problem: We try to configure Initial Sequence Number (ISN) Randomization
but we see varying information on CCO websites about its operation.
Details:
"I'm trying to determine the answer to the question: Do Cisco ASAs
randomise TCP Sequence Numbers between same security level interfaces
when using the Static command to do Static NAT?
Many thanks for your help
Regards , Hubert.
sebastan_bach Fri, 05/25/2007 - 12:03
i guess the isn randomisation is only for dynamic nat translations and not for static nats.
regards
sebastan
