May 21st, 2007
my company is having 515E with fos 6.3
and having 10 ipsec vpn tunnels with bandwidth 4 Mbps ... But I am getting only
500 Kbps per tunnel ... what SHALL i DO to improve the bandwidth used by each tunnel.. when no other tunnel are active?
I would be greateful to you .. if you can give some guide line on this regard
Overall Rating: 5 (1 ratings)
hoogen_82 Mon, 05/21/2007 - 09:30
Hi Swamy,
while initiating a ping from one PC to the destination use the following ping x.x.x.x -t -l 1500 -f
This will give you message that the packet is to be formatted
Keep decreasing this value till you come across a value which allows you to ping through the tunnel.
Then issue the command sysopt connection tcpmss {value}
THe value you got from the ping.
Do rate if this helps :)
