Adding HWIC 1FE to Cisco 2811
May 21st, 2007
I just added a new hwic to our router, to allow the addition of a DMZ, and when I booted the router back up the new interface does not show up. All of the lights are green on the back of the new ethernet port I added, but there is nothing in the config. I even tried switching the card to a different hwic slot.
Is there a command I am missing to do a hardware refresh or somtehing? I thought it would auto detect...
Will.
Martin Parry Mon, 05/21/2007 - 07:15
  • Silver, 250 points or more
Hi Will
Can you confirm what level of IOS you are running. HWIC-1FE and HWIC-2FE the minimum level is Cisco IOS 12.4(11) XJ
Martin
williamreed Mon, 05/21/2007 - 07:23
I found another thread which seemed to describe my exact problem, so I understand my IOS verion will need to be updated. You would think after paying $1000 for a card, you would be able to get the ios for free. My IOS Version is 12.4(3a). Any idea how I can get the new ios? I've never had to get one before.
Will...
Martin Parry Mon, 05/21/2007 - 07:32
If you have an active service contract you are entitled to IOS updates (within your current featureset) for free.
