MSFC interfaces
May 21st, 2007
I have never used a MSFC but I can see it has just as many options as a router would have but the only question I have is how do you configure the interfaces? I am going to be doing some inter-vlan routing and I dont get how I specify the interfaces and subinterfaces I want to route between. Any help I would be greatful. Thanks.
Overall Rating: 3 (1 ratings)
Jon Marshall Mon, 05/21/2007 - 06:35
You configure Switched Virtual interfaces for inter-vlan routing ie if you have a layer 2 vlan 20
msfc(config)# int vlan 20
msfc(config-if)# ip address x.x.x.x "subnet mask"
msfc(config-if)# no shut
For each vlan you want to route for you need a L3 vlan interface as above.
