05-21-2007 06:42 AM - edited 03-03-2019 05:04 PM
Cisco has a proprietary BGP attribute called weight. Why do we need it? It seems to me it does similar things, but has less capability, than local preference?
Solved! Go to Solution.
05-21-2007 07:02 AM
Weight is not a BGP attribute as it is not included in BGP update messages. It has only local significancy and has precedence over the local-preference.
Please refer to the following document for more information on the BGP Best Path Selection Process.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Hope this helps,
05-21-2007 07:11 AM
I forgot to answer the "why do we need it" part of your question.
It is mainly used to override any attributes that might be received from any other peers, especially in the case of locally originated prefixes (via redistribution or network statement).
Hope this helps,
05-21-2007 07:02 AM
Hope this helps,
05-21-2007 07:11 AM
Hope this helps,
05-21-2007 07:35 AM
That answers my question. Thanks a lot!
Cheers,
Sarah
