LMS 2.6: DCR behavior question
May 21st, 2007
If I overwrite the IP addr of a device in DCR, will my override be reverted later because the overwritten (but wrong) IP addr is what's in DNS, provided it stays wrong in DNS? Does it matter if the device is discovered by CM or added manually to DCR? Basically, I want to get LMS straightened out without waiting for the correction taking place in DNS.
Joe Clarke Mon, 05/21/2007 - 08:11
If you overwrite the IP address in DCR with an incorrect IP, that device will go unresponsive (or if the IP is reachable, it will be managed as a different device). If you are unsure about the IP, but know the hostname is correct, leave the IP address out altogether.
